lg 32lm6300pla Connecting bluetooth headset to LG 32LM6300PLA
By bos2prov
By JamesH
By Fredrik Andersson
By ato53
I have a new C4 TV.
Thanks for the follow-up
By Kane Murphy
- 2 answers
- 672 views
Using ARC sound bar and bluetooth headphones at same time C9 OLED TV
By Nigelrw,
- soundbar
- headphones
- (and 2 more)
- 3 answers
- 5,576 views
- 0 replies
- 2,650 views
- 0 replies
- 6,493 views
btbam
Hello everyone,
I recently bought a LG 32LM6300PLA Smart TV. I have a bluetooth headset and I'd like to use it as an audio output for my TV but when I try to pair it to the TV, the TV simply doesn't find it.
I'm new to the LG smart TVs world so I'm wondering if my TV can be paired just to compatible devices, and if yes, what kind of devices can I pair?
Thanks everyone.
