  • 26
Installing MX Player on LG Smart TV
my first post here.
I have the F770 front and rear in my Tesla and installed the Dash Cam Mobile Viewer app version 2.1.1 on my Android phone version 6.0.1.
When connected to the F770 wifi I wanted to see the movie clips and had to install the MX player for it.
That gave quite some issues:
1. after installing MX (1.8.9) and playing the first video, which didn't do it properly (see below), the app didn't respond anymore when trying to connect via wifi. I managed to get it working in the end via uninstalling and installing both the viewer and MX player.
2. opening the clips, opens the MX but there is no sound. No matter what settings I use; hw, sw, etc. (Sound on the phone is enabled. Sound works on pc viewer)
3. the clips don't play continuously. It starts playing, stops after half a second, pressing the play button, plays it for a second. Only after the third press it plays (without sound).
Are there specific settings I need to do in the MX player to get it working properly?
  On 12/8/2021 at 11:10 PM, miamaelia said:
my first post here.
Expand
no response.
is there any alternative that is available in LG Shop? i need to play video at certain speed, like 1,25x, 1,5x, 1,75x or 2x and my TV player can't do that... only youtube can... grrr
    • By Jack1151
    • By Will M
    • By Lesbo
