So I was using version 3.60.05 and this firmware was brill but now it’s updated to the latest UK version of WebOS the picture is pretty shitty I see lines or columns down the screen what version would you put on a 65SM9010PLA UK NanoCell tv.
I would contact LG support directly.
    • By SHawk
    • By Sqwazy
    • By majorusa
      - 3.23.24 - Romania- 47LB730v
    • By сергей фролов
    • By SailorMoon
