Downloading not supported
7 answers to this question
  • 1
Well trying to download livenettv the pop up message says "download not supported" How would I go about accessing Livenettv or any other suggestion of a available app which will allow viewing of F1, sports etc
At the moment only have Netflix
Are you trying to download an apk file into the tv??
You can only download and use app that are available in the LG Smart tv content store.
The other option is to get an Android TV box and connect same to your tv.
On 7/8/2024 at 11:26 AM, flora99 said:
You can use the Live NetTV (
) app if you want...
This link doesn't work. Please share the lin nux based version
    • By matesz
    • By dolbnya
    • By odesanmi kolade
      I have been trying to downloading Aptoide TV on my LG smart Tv but keep showing File downloading not supported.. My goal is how I can get zoom conference app running on my Smart Tv. Please help!!!
    • By Avnish Saxena
      There are many new movies and web series which are not playing.
      Jehanabad: in SoniLiv,  The Night Manager in Hotstar are couple of examples.
      They are playing flawlessly in Laptop and Mobile, but not in LG TV backed by webOS.
      I have removed and reinstalled both the Apps but no result.
      Please help.
    • Solution For That Pollution
    • By Cpetro
      Application like Crunchyroll and Viki are not supported in webOS.
      Can they be added? Or at least accessible from the browser.
