kodi app for WebOS?any other similar app?
By Rizwan Sumra
By starwoodtech
By Speedemon
I have a UK6300 LG TV. It has always worked faultlessly. However it now will not show the pointer unless I restart it and then it only there of only for 20 seconds and then it is gone. The LAN cable notification constantly disconnects and reconnects. The Web Browser no longer opens on my selected page. The Software version is the latest and when I tried to manually update the software in case the auto update got corrupted it will not recognize the USB drive as having the software on it. The software browser version is 05.50.15.
Any ideas what to do. I have two other LG TV's and all work perfectly.
By maninblack2000
I used the developer mode method to put Kodi on my TV, everything seemed to go to plan and it is there on the home screen but when I click on it it opens then closes again, does anyone have any idea why that is?
By fmas2
Hi everyone,
I´ve installed Kodi on LG WebOS. I need to delete some backups that by default are stored in the WebOS root system. I guess it can be done through WebOS Dev Manager but I´ll appreciate any help giving me the path to achieve such backup folder.
Many thanks in advance
- 0 replies
- 3,092 views
- 0 replies
- 2,099 views
- 6,960 views
- 4 answers
- 4,398 views
