LG webOS Magic Remote Not Working Properly
By Roy Brown
By Khelben Arunsun
By CJ Catalano
By magicschooldropout9
- 5,373 views
- 25 replies
- 21,111 views
Is it possible to program the color buttons on the Magic Remote?
By NikD63,
- magic remote
- program
- (and 1 more)
- 9,459 views
- 1 answer
- 3,510 views
