Hotstar language chage is not happening in LG smart TV model - 32LJ616D-TA/2018
By AJO
By Will M
By Lesbo
Ganapathi Nunna
Hotstar language change is not happening in LG 32 inch smart TV model - 32LJ616D-TA/2018.
TV software is up to date and there are no further updates, Screenshot is attached for our reference.
Regards,
Ganapathi
