Unable to connect to wifi
Still unable to connect to wifi. Unplugged TV from the wall. Unplugged/reset the router. Factory reset on TV. Any suggestions on how to get tv to connect to my wifi network?
4 answers to this question
Yes, the correct wifi passwordwas used. Wifi on this particular TV is the problem. Available wifi networks don't even show up, the TV just displays "searching" , when trying to connect to wifi.
@Yvette
I had a similar problem with my 55UH65T TV, there is issue with the WiFi connector kit and cable as per my discussion with the technician. If you have have similar model then I will suggest to call the LG support and get it replace if your TV is still under warranty.
I have WiFi problem after update to webOS 5.10.45 (55UK6950 TV). Wifi switch from menu randomly is ON/OFF sequence quite fast. Tried to reset to default, does not helped. Now streaming on wired connection and looking for solutions.
    • By agus
    • By Hasan Ghasabi-Oskoei
      Can you help?
    • By JamesH
    • By DavidSr
    • By Fredrik Andersson
