I have a 42 lg 3D Smart TV(42LB6500-TH) to with WEBOS version 1.4.0-2532, software version 05.05.70.
There are not more applications in LG store nor any application is able to cast from mobile into TV. Is there any casting application or does this support Chromecast.
Is there any way I can udate WebOS version.
    • By Junaid Ahmed
    • By Ganesh R
      Hi LG Team,
      Regards,
      Ganesh R
    • By Nishant singh
      Hi Team
    • Solution For That Pollution
    • By Gabor Monzak
      The LG Gallery is a very nice application, I use it many times, but unfortunately there are few classical paintings. Unfortunately, uploaded user images are represented by a variety of transitions and animations, which greatly worsens the artwork.
      It would be good if:
      - The number of factory-downloadable images would increase to multiple
      - Simply display user UHD images without any crossover animation (get the effect on and off)
      - It would be possible to play back-up images in random order.
