Youtube message
Hello all,
I hope you might help.
Youtube tells me it wiil shortly not be supporting my browser and I should update it.
I tried Google Chrome and it won't...and lost the will to live with Firefox.
As I have no idea which browser the TV uses, how might I update my browser?
Thanks in anticipation.
Jude
4 answers to this question
10 hours ago, Jude said:
Hello all,
Jude
Do you use your tv browser to access youtube? Your post is a little confusing.
lost the will to live with firefox?
You don’t have the Youtube app in your tv?
You don’t need  a browser to use youtube .
    • By JonoW
    • By Stephen Pritchard
      For some reason the scroll right and left arrows  have disappeared from the youtube app when using my mouse.
      I've tried installing the app again but no luck.
      Any ideas?
    • By Владимир Морозов
    • By Low Grade
      hi,
    • Solution For That Pollution
    • By netsplit
