What are 55SM8600 supported subtitle formats?
55SM8600 TV player plays video mp4, but it does not read subtitles. Name of video file is "A Journey to the End of Time.mp4", name of subtitles file is "A Journey to the End of Time.srt", they are in same directory of course. There are no other files with same name. Any computer video player reads both files without problem - exactly same files.
I attached subtiles file - should smart TV read it? If not, then what should be format? Please point to a working sample.
    • By Evelynn
    • By DeJaVu
    • By matesz
    • By Tsmt
      I have a problem with the subtitles when I try to share a video wirelessly directly from my PC to my LG 55SM9010PLA TV. I am not talking about sharing the whole screen (it lags a bit), just the video itself.
      Sharing the video itself works well, but randomly the TV randomly does not recognise the subtitle, the sub option is not active in the TV menu, and there are no subtitles. It is in the same folder on my PC as the movie (.mkv), with the same name. In case of some movies it works, in case of others not, and I do not see the reasons why.
      First I tought it is becouse the format of the subtitle needs to be ".sub", becouse it worked with one movie. So I have learnt how to convert properly ".srt" to ".sub" - but still no success.
      Then I realised, in the case of another movie ".srt" worked on the TV, so I got really confused.
      I see no logic behind it.  Could you help me, what is the key here, what am I missing?
      Thank you!
    • By dolbnya
