LG WebOS. Are DLNA external subtitles supported?
Hi guys,
I wanted to know if native WebOS media player on LG tvs, support streaming of movies with EXTERNAL subtitles present in folder where the movie is - via DLNA
I purchased Sony XG95 recently, but it seems that native player does not support DLNA external subtitles - only embedded ones. This is joke as even my old samsung from 2015 could deal with it.
Is anyone perhaps streaming movies via NAS using DLNA server (like Universal media Server, TwonkyServer, Servioo) and can confirm whether external subtitles are supported or not?
I'm considering switching to LG C9 oled if it has support for these DLNA subtitles.
DNLA subtitles are supported but not in all languages (as you can find on this forum).
The Media player is a bit simple. It works with Serviio (I have used it) but there are nicer solutions.
I myself use Plex but there are more apps that do the same.  For Plex there is a native app on the TV and that works great.
    • By tarakdave
    • By Nick Payne
    • By Bella Lee
    • By Alex
      Samsung has made fridges with touchscreens before. LG has made fridges with doors that turn transparent to show you the inside. This year at CES 2018, those two ideas are finally merging into one with LG’s new InstaView ThinQ smart refrigerator, which features a 29-inch touchscreen that becomes transparent if users knock on it twice.
      LG actually tried this two years ago, with a version called the Smart InstaView Door-in-Door that ran a full version of Windows 10, but it’s not clear that the company ever shipped the Windows version.
      Unfortunately, the only image that LG has shared showing the fridge is a low-resolution shot on its YouTube page banner, but it seems that you’ll be able to still use the screen while it’s translucent, allowing you to tag food directly in a vaguely augmented reality-esque move.
      Source:
    • Solution For That Pollution
    • By MURAD
