LG UHD UK6360 picture quality goes dull after firware update to 05.10.45
I recently updated my LG UHD UK6360 firmware to 05.10.45. However, after update I see picture quality has been reduced and seems to be very dull in nature. Any user experiencing  the same issue? Is there any way to restore old firmware?
5 answers to this question
Check the Vivid color temperature setting.
Are you talking about watching something through HDMI,  or some of the built in apps?
If it's the same everywhere, unplug the TV from the power for at least 15 minutes
plug it back and retry
    • By JRay
    • By Ajothen
      Key Specifications:
    • Solution For That Pollution
    • By forum1
      My LG 49UB850V LED TV  browser is too old. The most of the pages not work any more. How to easy update just one simple browser app? For example, often browser show error during open new page. It show certificate expire problem and page not load at all.
      This mean LG sell product without update at least browser certificate and now we are stuck and can not even load one page from WWW.
      Shame on you LG. I will not buy any more from you.  How dificolt is to release new update to update OS certificates? Microsoft Windows did this, android did also for old phones, etc... Really, can not undestend this asian people from Korea.
