LG UHD UK6360 picture quality reduces & seems dull after firmware update to 05.10.45
I recently updated my LG UHD UK6360 firmware to 05.10.45. However, after update I see picture quality has been reduced and seems to be very dull in nature. Any user experiencing  the same issue? Is there any way to restore old firmware?
    • By atcronin
    • By mean2
    • By PVD
    • By JRay
