Lg,
We really need option like data saver that is available in android TV's, that's really sorts out our data cap problems.
Why lg is ignoring the software support though the hardware of the TV's support lots of features.
Please plan something big with feature rich update ....... Really needed lot of changes, soon this frustration become hate.
    • By garamja
    • By ato53
      I have a new C4 TV.
      Thanks for the follow-up
    • By JonoW
    • By Rayman
      I know I can root webos to install piccap and use that for ambilight (
      But why cant we have an official app that sends the picture information so we can make our custom ambilight for webos without rooting it ?
    • By netsplit
