Web os version 3.8.0 update
By Roy Brown
By Tobin
Tobin
By DavidSr
By JRay
By NaveenKumar
Latest version of sun NXT app version 8.0.20 is not working for web os Tv version 4.4.2-11 plz do the needful full & Airtel Xstream is not found in your web os platform kindly check on that too
Azogui
Is it possible to update the version of my web os to 4.0? If so, how?
my tv is LG OLED65C7-Z
thanks in advance.
