Dear sir ,
I am not able to screen sharing or mirroring between lg 65uk7500pta and iPhone XR .there is no option available in screen cast for iPhone ,this is premium brand how you can ignore this pls tell me the solution.
Dear sir ,
Try the below
Hope this helps.
On 5/10/2020 at 6:28 PM, shelu parmar said:
Dear sir ,
You can’t. UK7500 is a 2018 model AFAIK so it doesn’t support airplay. The screen mirroring/sharing feature for apple devices is called Airplay.
It was introduced in LG tvs from 2019. The 2019 onward series models come with Airplay 2 support. For instance 65UM7300 etc..
UK7500 won’t be getting Airplay support ever. It will do get the apple tv app by end of year. The only solution is getting an apple tv for Airplay 2 support.
 Airplay is NOT supported by LG WebOS or for that matter most of Android/Linux Smart TVs. You need a 3rd party streaming apps on both devices if you want to stream it. Let me warn you... the quality is useless and you will be very dissatisfied with the result.
Get Apple TV if you really want to use AirPlay extensiely.
AirPlay  isnt supported, but AirPlay 2 IS, My TV supports it and it works flawlessly.
    • By DWINKS49
    • By Batman
    • By wallyricks
      Transitioning Between Transparent to Opaque Screen, LG SIGNATURE OLED T
      Introduces New Viewing Possibilities and a New Era in Home Entertainment
      SEOUL, Dec. 19, 2024 — LG Electronics (LG) is set for the global launch of the 77-inch LG SIGNATURE OLED T, the world’s first transparent and true wireless 4K OLED TV. This groundbreaking model will be available in the U.S. this December, with additional markets to follow.
      Unveiled at CES® 2024, the LG SIGNATURE OLED T represents a monumental leap in both technology and design innovation, reflecting LG’s relentless drive to delivering new and better. Its cutting-edge self-lit screen can transform from transparent to opaque screen; a unique ability that provides the OLED viewing experience while offering greater freedom in living space. Recognized globally, LG’s transparent OLED made TIME’s Best Inventions 2024 list and received a total of five CES 2024 Innovation Awards, including a Best of Innovation honor.
      Users can effortlessly switch between transparent and opaque modes at the touch of a button, unlocking unique possibilities for entertainment and space design. When in transparent mode, the OLED T offers a futuristic content experience that must be seen to be believed. The screen not only creates the illusion of content floating in mid-air but also produces a mesmerizing effect by “merging” the on-screen visuals with the surrounding space.
      LG OLED T further elevates the user experience with a suite of versatile features that optimally leverage the unique advantages of a transparent OLED screen, enhancing its distinctive value.
      One standout feature is T-Objet, an Always-On-Display (AOD) mode that transforms the screen into a transparent digital canvas, ideal for showcasing artwork, videos or photos in outstanding color and clarity. Complementing this is T-Bar, a sleek info-ticker that appears along the bottom edge of the screen, providing sports results, IoT device statuses, weather forecasts or song title information. The rest of the screen remains unused when T-Bar is active, presenting a clean, uncluttered look and a clear view of the space behind LG’s “virtually invisible” display. For added convenience, T-Home offers a user-friendly interface that delivers a well-organized overview of available services, as well as quick access to apps, settings and other features.
      Despite its stunning 77-inch screen size, the LG OLED T enhances the feeling of space within a room, providing a sense of openness that conventional TVs simply cannot. Its transparency allows it to be placed centrally without being obtrusive or positioned in front of windows without blocking natural light or views of the outdoors.
      The transparent 4K OLED screen, combined with LG’s true wireless video and audio transmission technology, promises not only the aesthetic value but also an enhanced home entertainment experience. Free from tangled cables, the device delivers an immersive, distraction-free viewing environment.
      The OLED T advances innovation with LG’s proprietary Zero Connect Box, a visually lossless wireless video and audio transmission solution* without latency ensuring a seamless viewing experience. By supporting 4K at 120Hz variable refresh rate, OLED T has been certified by NVIDIA G-SYNC® Compatible and AMD FreeSync Premium to eliminate tearing and stuttering for the most dynamic, true-to-life gaming experience.
      The LG SIGNATURE OLED T carries forward LG’s legacy of providing superior picture quality and immersive viewing experiences – hallmarks of LG OLED TVs since the very first model hit the market in 2013. Building on over a decade of OLED innovation, LG’s one-of-a-kind TV brings images fully to life with vibrant, precisely reproduced colors and incredible contrast. Powered by LG’s advanced α (Alpha) 11 AI processor, the OLED T intelligently optimizes both picture and sound quality, delivering unparalleled visual and auditory experiences.
      “LG SIGNATURE OLED T is an exceptional user-focused innovation that offers a distinctive, multi-faceted viewing experience and unprecedented spatial flexibility,” said Park Hyoung-sei, president of the LG Media Entertainment Solution Company. “LG remains at the forefront of innovation by combining its industry-leading OLED technology with unique form factors, transparent screens, wireless connectivity and more, delivering unparalleled, life-enriching advancements no other TV maker can replicate.”
      * Wireless transmission refers to the transferring of video and audio signals between a TV screen and the Zero Connect Box. Visually lossless, based on internal test results with ISO/IEC 29170-2 and measurement results may vary depending on connection status.
