Has anyone had any luck hooking up a Bluetooth dongle to their TV and having WebOS recognize it?  I'm about to buy a replacement BT dongle from Amazon for my laptop and wanted to see if any particular make/model worked for them. Thanks!
3 answers to this question
Well, I have tried at least a dozen of them... from cheap $4 to $25 USB dongles but none was recognized by the LG WebOS.
My Magic Remote stopped working on my TV and then I tried other remote from my other LG Smart TV, realized that its not the remote but the Built in Bluetooth Receiver has conked off.
So, been trying all sorts of Bluetooth dongles including some claimed to work on LG TV, still no luck. LG Support is not much helpful either with it.
I get the same reply to change the remote...!!!
Why don't u download the LG TV Plus App or LG ThinQ App from the App Store and use your cellphone as a Remote controller. You will control the TV using Wi-Fi connection not Bluetooth
well, I appreciate your response, the idea is to use the remote control for the purpose it is provided so that anyone in the house can use it. if you try the app, you will notice the lag and repeated disconnection... it is not something that you would expect from a remote control.
So, after all there is NO More Magic with the Magic remote control...!!! Lol.
    • By JamesH
    • By Fredrik Andersson
    • By ato53
      I have a new C4 TV.
      Thanks for the follow-up
    • By Kane Murphy
    • By janisad
      I have an LG 32LJ610V TV.
