Hi. I've got a MKV file with 20+ subtitles. Subtitle I need is at position 18. When I connect the USB disc to the TV,  default LG media player plays it, but when I try to select the 18th subtitle, media player only shows 12... no more... No way I can access subtitles more than that.
This is a clear bug. Any way to fix this? Is there a better media player app I could install  that can handle more than 12 subtitles in an MKV file?
Assuming this MKV file was ripped from DVD or BD (legally of course), when ripping you should have selected only the subtitle track you needed, #18, rather than the bizarrely large assemblage of all the tracks.
    • By Prakash Sahoo
      Hi Team,
      Prakash Sahoo
    • By wallyricks
    • By Jaswinder Sandhu
    • By tarakdave
