Xtream box is not working with LG 4k tb
LG 4k TV is not supporting xtream box.
I have LG 4k HDR tv and yesterday I purchased xtream set up box. Once I turn off HDR from tv settings, it asks to reboot for settings to take effect. After I reboot, TV automatically detects HDR enabled input, and enables HDR. I have not found a way to disable HDR from xstream box settings. No solution in sight. Please help this is an issue with STB.
Why do you want to disable HDR?
Xstream box functions in HDR mode only with HDR TVs. Although the non HDR content(tv channels) will display as non HDR (SDR) and HDR content ( from netflix and prime) as HDR.
TV will always indicate it is receiving an HDR signal for all content.
    • By Rex G
    • By sudar shan
    • By NaveenKumar
    • By jcol5786
