  • 4 weeks later...
 How do I install HTML 5 player or silverlight to watch Netflix on LG smart tv
Go to LG store and download/install Netflix if it's not already installed on your tv.
    • By Nicola123
    • By svsrama
      Sriram.
    • By cptl
      Any thoughts?
    • By Sandtonman
      Dolby Vision is 22.11.
    • By Edgar Corona
      I have a 55" smartv, i'm having problems with Netflix app, anyone knows why, i can't open de app, everything after and update send it by the tv..
