Hi!!!
The thing goes like this.  I've shared a folder in a Win7 PC, the folder has one video and one sub srt file.
When i access from my LG 50uk6550 TV the video loads perfectly but the subs won't load.-
If I copy everything in a pendrive and plug it to the USB everything works wonderfull, but not from the network folder.
Is there any solution??
Thanks in advance!!
    • By keshav iyer
    • By MURAD
    • By akhil7j
    • By jcol5786
    • Solution For That Pollution
    • By alfie
