How to install webos newer version manually ?
Hello.. I want to install latest webos system version to my tv .. I think rooting it may help .. is there any guide or steps to follow to do that ?
Also I want to be able to rollback to my current version if the install with root failed due to drivers for example.
    • By Prakash Sahoo
      Hi Team,
      Prakash Sahoo
    • By anna groove
