When I try and connect to my All4 app I get error message 'Server Certificate has expired or is not yet valid as the set time on TV is different from the current time'.
cAN ANYONE HELP
    • By Batman
    • By Marko00
      only with cancel button.
      How to fix it?
    • By leader6234
      Hey guys !!!
      Thanks in advance !!!
    • By Muser
