HBO Max LG webOS TV
HBO Max came out recently and unfortunately they haven't built an app for lg webOS TVs yet.
The following devices are supported by HBO Max. If a device is supported, you'll find the HBO Max app in the app store.
  • Android phones and tablets (with Android OS 5+)
  • Android TV (OS 5+)
  • Apple TV (4th gen and later)
  • Chromebooks
  • Chromecast
  • iPhone, iPad, and iPod touch (with iOS 12.2+)
  • PC and Mac computers
  • PlayStation 4
  • Samsung TV (2016+)
  • Xbox One
So if you have any of these devices hooked up to your LG webOS TV your solution is to use one of these methods.
You can also contact HBO directly by email at [email protected]
I have a LG TV and I am waiting for them to launch HBO MAX on LG TV as well.
Until then i would use the Screen mirror option to mirror the video on TV.
I hope they come out with an app for LG Web OS TV as well.
But mirroring does not give good experience on the TV. The audio and Video get cut sometimes and the they mismatch each other as well.
  • 6 months later...
  • 7 months later...
  • 5 weeks later...
  • 4 weeks later...
On 9/10/2021 at 2:31 PM, Alex said:
HBO Max should be live:
HBO Max LG TV
Why don't I see this on my webOS TV UJ6300 Software Version 6.00.04? When I check for updates, No updates found so I assume I'm running the latest version.
