Not Connected to Wi-Fi (Error 106 and subsequently 137)
Reset our router (turn off then turned on again  and waited) but now no networks are even found to attempt to connect to.
Any suggestions what my next step should be?  This has happened suddenly.  Thanks
3 answers to this question
Fixed it by :
1. Unplugging both modem/Router & TV
2. Plugged in Modem/Router and let it restart
3.Plugged TV back in and turned on ......connection was made successfully
WTF?
@geoffHome First, what is the TV model number, and the router make and model? It is often good to ensure that the TV has the latest firmware, AND the router too. I assume you can log into the router? NOTE: many non-tech users do NOT think about the router, as it just sits there and works (until it doesn't), and do not think about the default router admin password, that is often just admin with a password of admin, which is a very insecure situation, and leaves your router open to hacking. It is best to change that, if you have not done that already, and if you CAN log in via a laptop/PC, do so and check the system log and security log (you can usually use 192.168.1.1 or 192.168.1.254 as the "URL" in your browser). The router hardware is comprised of several internal discreet sections, with the Ethernet LAN part and the WiFi parts driven by separate software routines, any of which can crash, and exit the router memory,and do not always auto-restart. VOIP software is typical for this too.
Make sure that your WiFi strength is good where your TV is (use a smart phone to check the signal bars), and if the 5G band is weak, switch he TV to the 2.4G one.
If your LG TV is not connecting to the Wi-Fi, try resetting it. Press the power off button for 30 seconds, and it will turn off. Then, please wait for 2 minutes, and then restart it. It will start working.
    • By NickL
      Br,
      Nick
    • By agus
    • By Kane Murphy
    • By Marko00
      only with cancel button.
      How to fix it?
    • By Tunari
