By
atcronin
Ankur Saxena
HI I have purchased a new LG smart tv where all Apps are working perfectly fine except Voot. After downloading Voot whenever i launch Voot the circle keep on going and Content is not coming. I have uninstalled nd install the app many times but the same problem persists. Pls suggest and help.
