14 answers to this question
Is is possible to record live tv  which is connected with HDMI cable
If its live TV and you have a USB connected to your TV, then you should be able record on it.
USB is connected to my TV... But on recording it says signal not supported and recording  stops
I am not able to record live TV which is connected through HDMI 3. Even i have connected USB. The error it gives me on recording is "SIGNAL NOT SUPPORTED"
Ah! now I understand what you are trying to do. I don't think you can record via HDMI. If you are using a TV box e.g Vodafone or Sky or something similar, you should check if it's supports live recording.
Do you know any another way of recording (Legally or Illegally). Please let me know...
My LG Tv is SmartTV and I think recording should be possible on Smart TV's
LG Smart TVs are the among the few TVs that can mainly record live signals e.g antenna. To record via HDMI, you would need either a set-top box or HDMI recorder.
Posted (edited)
@anand shinde  Have you checked the "Time Machine" app on the TV? Most LG models from about 2014 onward have this.  You DO need to attache a decent capacity (e.g. 1TB to 2TB) sized HDD (portable hard disk, e.g. the Seagate backup disks, that are quite cheap these days, and are self-powered from the USB socket). They come with a SHORT usb3.0 cable, that needs to go into the socket that supports USB3, but the normal socket will work. I usually use a cable tie, or velcro cable tidy, to support it at the rear of the TV, or in the bracket.
You can use the DEVICE links on the TV to set up so it "sees" the new disk OK, then go to the Time Machine app, check the TV Guide link, select from there, it can create a recording schedule. Once the entry is there, you can edit that schedule (start and stop times, once or weekly etc).
DOWNSIDE: the recording function (Time Machine) lacks the intelligence of a Sky or Foxtel box on older smart TV's, but MIGHT be better on recent ones. This may mean that if you program starts EARLY, the title will reflect THAT program on-air at the time, and NOT the programme name of what actually WILL be recording.  Deleting them after can be a bit "clunky" and unintuitive with ticking boxes and using the waste-bin icon, but you get used to it over time.
Edited by td47
add OP name
@anand shinde ALSO - with regard to recording via HDMI, because of DRM and Copyright issues, this connection type uses HDCP technology to stop that. However, some forums show that some HDMI splitters will remove that connection path, and allow screenshots atc, BUT anything else is deemed illegal:
See:
@anand shinde FYI: Time Machine functions in newer TV models is now called Time machine II, and is driven mainly from the Magic Remote Q.MENU, so it might not be visible as an actual separate app. If you tell us your LG model number, we might be able to provide more relevant help for recording functionality, tips and info. In the meantime, have a read of this LG article:
 @anand shinde Thanks for the model number (43UK6780PTE). I see from the spec that it is "Time Machine Ready" so the functionality IS there, but it will need a small self-powered HDD (external backup type of hard disk) plugged into the USB3 socket to activate the recording functionality that the TV has. NOTE: the new disk when added, may trigger a recording "setup" automatically anyway, so be aware that it may well want to format it to the TV requirements (file structures, folder names etc), that may take a few minutes. Use Velcro or a cable tie to hold the external disk in a convenient place, so that it does not strain the connection cable (NEVER let it hang from the cable).
ALSO: be aware that even when in standby, the TV will still have enough "smart electronic logic" active to do the scheduled recordings on its own, it does NOT need to be in the ON state, BUT DO NOT TURN IT OFF AT THE WALL SOCKET OBVIOUSLY! ☺️
Did you read the link for the smart remote info in the link I posted above? It may be a different one, and I am having a hard time finding the "Q.MENU" button, that in one of them is a button marked "123". If you had a separate manual for your remote, have a good read to see if it helps with the recording side. It MIGHT be the "settings" cog button on yours, I am not sure.
I know that the smart remotes have a good voice command function, so press the button to activate the microphone and try saying "time machine". I find the voice command useful to get to "settings" with my older magic remote, as I can never remember how to get to it on my TV otherwise... 😊
 @anand shinde
By the way, I find that Toshiba or Seagate portable USB3 dives are good for this, use this Google search term to see what is available in your area:
"site:.uk toshiba portable drive" or "site:.uk seagate portable drive" without the quotes. The site thing limits sites to your country.
I tried with voice command but it says " Current status of your tv doesn't support this time machine function"
@anand shinde I suspect that it knows you don't yet have an external HDD (Hard disk) plugged into a USB (Ideally the USB3 socket), so it cannot support recording until you do. By the way. did you seee my other post about typical/good HDD portable drives to use:
Bye the way, I find that Toshiba or Seagate portable USB3 dives are good for this, use this Google search term to see what is available in your area:
"site:.uk toshiba portable drive" or "site:.uk seagate portable drive" without the quotes. The site thing limits sites to your country."
Hi ,
TIME machin WORKING with only AV Connectivity or AUX cable Connectivity . Not through HDMI.
and 2nd is Set in TV gmt time setting or date setting . AFTER THAN you can record your TV program in one drive or HDD.
Thank you
Krishna kumar
    • By Venkata
      Hello Team,
    • By OliverRC
    • By hollean
    • By JamieG
    • By Kane Murphy
