Hi Guys,
just wondering if any of you experienced channels lost on freeview, its happend now quite often ( about 4 times)
Any ideas or tips about it?
LG model 43UM7000PLA UK
Any help would be great
Thank you
L
Freeview have reorganised their channels. Some have moved and 3 or 4 have been withdrawn. It was advised in advance with a message that had to be cleared using the yellow button. Google Freeview changes June 2020. It is for once not an LG issue .
    • By John Phillips
      Can you upgrade Freeview to Freeview Play??
      Regards
      John
    • By nigelh
      I have an LG43UN71006LB TV. I don't have an option to download the Freeview app. When I search for it in Content it isn't found. However I was told that the app should be available on this model. Would appreciate if anyone could confirm I this is the case and if so why it isn't available to download.
    • By jcol5786
    • By Rizwan Sumra
