Hello guys and gals,
I am not sure if this question is for here, but i tried reading some posts on the internet and could not find a reasonable explanation or solution to my problem, so here it is.
I bought my TV (official model i think is OLED55CX3LA) about 2 weeks ago along with LG Soundbar SN4, connected via optical cabel.
In few words, the setup is as follows:
- Picture mode - Expert (Dark Room) with Gamma set to 2.2 and TruMotion to Natural
- Sound is set to Cinema mode and Optical+Internal TV Speaker
No AI features are turned on and TV is connected to internet via ethernet cable. I have set-up box connected to the TV, a laptop, both with HDMI, and streaming with Serviio over dlna.
Now the issue. On 3rd-4th day the TV started crashing only while watching from the set-up box. The picture will freeze, some times a high pitch noise appears, the TV is unresponsive. This goes on for 10-20 seconds, the TV turns off by itself and after 5 seconds it is turned on. Sometimes it does it once and not again, sometimes there is a day without doing it, sometimes does it constantly one after another unless i change the channel, or change from set-up box to DLNA for example.
I changed HDMI ports, i changed HDMI cables - no effect. I thought it is something in the signal from the set-up box (sometimes it is very low quality, or whatever else), but yesterday same thing happened while watching 2160p movie from DLNA.
You can see what happens here:
The video on my cloud is only 2 minutes, but in reality this went on for about 7-8 minutes until i changed from set-up box to DLNA. Just the video was too big and had to cut it.
Thank you!
7 answers to this question
I was experiencing what sounds like this problem. (C9 with sound bar) It wasn’t happening often and hasn’t occurred since the last firmware update about 10 days ago. Have you updated?
Hi kpodolinsky My name is krishna from india. 1st reset Your TV , 2nd Connect your sound bar via TV sound sync , 3rd set Your picture mode in standard , 4th Go to the setting pixel refresher option and do and last one check Your software updation.
Thank you
Krishna kumar
Product Trainer
LG INDIA PVT LTD
Hello Krishna Kumar,
Thank you for the help!Unfortunately my TV does not seem to have TV Sound sync as option(Uploaded picture of the current options). I previously had the soundbar
connected via bluetooth but this had a lot of issues from sound delay perspective(issue with TV crashing was still visible), so i had to connect it via optical cable. Also i would like to still use internal speakers + soundbar as audio.
I also did the pixel refresher procedure 2 (or 3 times, not sure) already.
Also uploaded picture of the current software version - no newer one when i press check for updates.
IMG_5556.thumb.jpg.8578b9b40d514807dd8c37fd8b2abbb3.jpgIMG_5557.thumb.jpg.5553eaaa47da720b3e4ccbbfd0413215.jpg
Thank you!
Hi there, did you ever resolve this problem? I’m having the same exact issue. I’ve read it might be related to overheating due to the wifi cheap. Curious to know if you ever figured out your issue or just ended up getting it repaired or replaced?
i tried everything but nothing helped. I called local LG representative and they sent couple of guys with fancy looking remote. They were able to enter some hidden menus and troubleshooting options, which showed error code related to what they said communication issue between motherboard and processor.
so they took the TV. After a few weeks they returned it with replaced motherboard and no issues since.
    • By Nick Payne
      We have a 65" G1 OLED set. Lately (like the past couple of months), at irregular intervals while the set is on, it will power itself down without any input from the remote. Happens maybe once every two or three days. Powering it on again using the remote always brings it back to life OK. Unsure whether this is a hardware or software problem, and can't see how I could determine whether it's one or the other. Any suggestions? The TV is current with whatever the lastest level of FW is - I just checked in settings and was told there were no updates available.
    • By OliverRC
      Dominating With Over 52.4 Percent Market Share in 2024,
      Company Reinforces Its Unrivaled Leadership in Premium TVs
      SEOUL, March 12, 2025 — LG Electronics (LG) has reaffirmed its dominance in the premium TV market, leading global OLED TV shipments in 2024 with over 52.4 percent of the market share. For 12 consecutive years, LG has commanded the global OLED TV market, continually enhancing the TV experience with audiovisual excellence and AI-powered personalization, embodying the true essence of OLED technology with perfect black levels and enhanced brightness.
      According to market research firm Omdia, LG secured the top spot in the global OLED TV market last year, shipping an impressive 3.18 million OLED TV units. Notably, fourth-quarter shipments alone surpassed 1.1 million units, showcasing the company’s ability to deliver cutting-edge technology that meets evolving consumer preferences.
      OLED TVs accounted for 45 percent of the premium TV market in 2023, based on models priced at USD 1,500 and above, marking an 8.5 percentage point increase from the previous year. With the market expected to exceed 50 percent this year, LG is committed to driving innovation and maintaining its leadership in the OLED TV industry.
      As demand for larger screens continues to rise, the number of ultra-large OLED TV shipments has also increased, comprising 16 percent of the entire OLED TV market. LG remains at the forefront, dominating the market with a 57.5 percent share in 2024 for OLED screens of 75 inches and above, including a compelling selection of 77-inch, 83-inch, 88-inch and 97-inch models.
      Backed by over a decade of OLED innovation, LG is set to introduce its latest OLED TVs, featuring advancements like wireless transmission of audio and visual content up to 4K 144Hz with no latency or loss in quality, AI-powered personalization through webOS, and superior picture quality with enhanced brightness and perfect black levels for a truly exceptional viewing experience.
      Global TV shipments reached 208.8 million units last year, marking a return to growth after three years, with OLED TV shipments rising 8 percent year-on-year to 6.07 million units. Additionally, LG’s total TV shipments across both OLED and LCD models reached 22.6 million units last year, representing 16.1 percent of global TV market revenue.
      Have you ever wondered how many LG OLED TVs are shipped every year? 100 thousand units perhaps, maybe as much as a million? In the first half of 2023, LG recorded over 1.33 million shipments of its stunning OLED TVs, setting new benchmarks and records its competitors can only dream of.
      link hidden, please login to view, LG captured over 55 percent of the global OLED TV market in the first six months based on total shipments. As a renowned OLED TV leader now celebrating 10 years of innovation in this space, LG has once again defended its premium TV crown while further cementing LG OLED TV’s status as the pinnacle of premium TVs.
      The “bigger the better” trend continues to prevail in the TV market, which is great news for LG. As more and more people desire larger TVs for their living spaces, models of 75 inches or larger accounted for a remarkable 11.4 percent share of total OLED TVs sold, while shipments’ yearly average growth rate topped 90 percent over the past five years. Staying on top of this growing trend, LG is resuming its dominance in the market with an outstanding 64.2 percent share in total shipments of OLED TVs over 75 inches.
      LG is targeting this new demand for large and premium TVs in the second half of 2023 with the groundbreaking TV (model 97M3) it unveiled in July, which boasts the world’s first 4K 120Hz wireless solution that makes it easy for customers to achieve their dream interior.
      Not one to be confined, LG unleashed a tidal wave of 10 million TV units (OLED and LCD) on the world, which has helped the company carve out a 16.2 percent share of revenue for itself in the global TV market.
      Despite facing a downturn in the global TV market, LG persisted in strengthening its inventory management and securing higher profits while actively pursuing a strategic approach for its premium and ultra-large displays. And this commitment has paid off substantially, with its LG OLED TVs now accounting for around 30 percent of the company’s overall revenue generated from TV sets.
      TV shipments totaled over 92 million units in the first half of 2023, matching last year’s first half performance. The OLED TV segment, which has been led by LG for a number of years, has already passed the 2 million shipments mark this year, which bodes well for the rest of 2023.
      OLED TVs are continuing their takeover of the global TV market after capturing 9.3 percent of all revenue in the first half. Meanwhile, Omdia predicts that OLED TVs are set to shine even brighter, projecting at least a 43 percent revenue share among premium TVs priced above USD 1,500.
      Find all the latest news on the home entertainment business and learn more about its world-leading innovations on the LG Newsroom.
