Bluetooth headphones and internal speakers together
By JamesH
By Fredrik Andersson
By ato53
I have a new C4 TV.
Thanks for the follow-up
By Kane Murphy
By John Nguyen
bigshuirs
I am a bit hard of hearing so use a set of bluetooth headphones with my laptop I would like to use them with my LG tv whilst the rest of the family use the internal speakers to listen to it
but that does not seem possible
any ideas
7 answers to this question
