By Khelben Arunsun
By Prakash Sahoo
Hi Team,
Prakash Sahoo
By tarakdave
By AtWitsEnd696
- 1 answer
- 621 views
- 1 reply
- 2,072 views
- 8 replies
- 35,496 views
- 2,308 views
sharathks00
I have
LG webOS TV UF950T,
software version 04.06.00
1.) WebOS is getting updates but new apps are not showing up in LG Content store. When I visit
2) When i try to play a video some times it says video format not supported and some times audio format not supported like with opus & ogg.
My question is to Manufacturers/ WebOs designers if this is the case what is the point in updating TV, when there are no apps or support for new video or audio formats ????
In this case its like if i want new apps, I have to buy a new TV, updates are not helping in improving TV in any ways, no longer a Smart TV
lol
