NES / SNES / GBA Emulator port
By pivotCE
Tools for the Job
– Needle nose pliers/tweezers
– Flush cuts
– Painter’s and kapton tape
Trim the USB C Board
Tape the USB C Board
Where To Get Power and Data
Put the Pieces Together
Congrats, You Now Have USB C
#webOS4ever
By KNICKNL
TV: LG OLED65C16LA
I have a Sonos ARC Center Speaker connected to the HDMI eARC port, when this happens bluetooth function on TV does not stay activated, is there a solution?
By Jim Brown
I have a LG OLED C8 TV with a Soundbar and when connected to Optical the Volume Control is normal with a Percentage 0% to 100% but when connecting to HDMI ARC port like the Soundbar suggest to be connected it just show + or -, you don't have anyway of knowing what the volume is set to. I have tried two Soundbars a LG LAS551H that was connected via Optical and when connected to HDMI ARC it also does not show Volume Control. I have got a new Sonos Beam Gen 2 that is now connected to HDMI ARC port and sounds great but if I connect it to Optical it's much lower in volume but has the Volume indicator. Please advice.
I would like to suggest three enhancement request: 1. to show Volume Percentage on the HDMI ARC port. 2. Optical and HDMI ARC have the same output and 3. the Sonos be added to the Device list under Soundbars.
Thank you,
Jim Brown
By Hùng Mạnh
Hi everyone,
I was trying to install an environment to develop.
But I can't run the emulator (Version 5).
I always get this error prompt.
Please help me. Thank you.
By Jim Brown
Thank you,
Jim Brown
- 5 answers
- 571 views
- 6,624 views
- 1 reply
- 3,545 views
ares-launch ERR! CLI: luna-send command failed <Failed to launch webapp in WAM>
By Syed Jalal,
- ares-launch
- emulator
- (and 1 more)
- 1 reply
- 5,099 views
