Posted (edited)
On certain scenarios, I notice barely visible Elongated rectangular lines on the LEFT side of my screen?
Please advise
John M.
Edited by John Magann
cHANGE RIGHT TO LEFT
Please advise
John M.
Sounds like a physical fault, a picture would paint a thousand words.  Is the TV under warrany?
    • By Anthony Vaccari
      Hi there to anyone who can help. I'm issuing problems with dark scenes with my LG 55uf770v and options screens showing up pixelated blacks. This happens through Netflix, ps4 Pro and skybox HD. I have tried all sorts from tampering with picture settings on all devices. I've had the TV for about 2 years and it's now out of warranty which is a bit of a stinger as it cost £980 at the time. Does anyone have a solution.
    • By alan dickinson
      I have two very thin but very distinct parallel, vertical lines on the left of my screen. Is this a hardware or software problem?
      Sometimes you just need a quick classic game to fill some idle time in your day. In the old days you'd grab a piece of paper and set up the four lines for tic-tac-toe, or if you were feeling particularly ambitious you might lay out a grid of dots for a game of dots-and-lines. Thanks to the magic of tablets, you can make a quick game tic-tac-toe happen, or if you're in that particularly ambitious mood you can turn to
      link hidden, please login to view for the paper classic.
      One year ago, one of our favorite webOS Twitter client -
      link hidden, please login to view - launched into the App Catalog for webOS smartphones. That was a different time, and the past year has been , enough to give any mobile developer the chills. has fought through those chills to release and with a slew of fixes. But one can only handle so much, and the small development firm of dots & lines has decided to call it quits on webOS. Citing the continued cost of development to keep up with changes to Twitter's APIs and user expectations coupled with unsurprisingly declining sales, dots & lines made the decision to pull both Carbon and Graphite from the App Catalog. That means no more sales for either app, but it also means that existing purchasers of the app won't be able to redownload the apps after deleting them or when setting up a new webOS device.
      While we can understand the thought process behind ceasing development on Carbon and Graphite, especially with dots & lines already having released and with in alpha and Carbon for iOS on the drawing boards. We are disappointed by the decision to pull Carbon and Graphite from the App Catalog, as it denies current users the option to redownload it in the future. Sure, Carbon stands a very good chance of becoming abandonware as Twitter makes changes that break the current API implementation, but we know that now going forward. Then again, new purchasers might not realize that and could be stuck with an app that only functions for a short time. dots & lines is at least considering open sourcing the code for Carbon, even if it is the year-old Mojo framework and not the newer Enyo.
      Update: dots & lines has that they are offering refunds to anybody who purchased Carbon or Graphite for webOS in the last two weeks.
