Youtube player control focus
By Lee Magee
By Will M
By David Joseph
By wallyricks
By Владимир Морозов
KARUPPASAMY KANNAN
Hi Team,
I have implemented embed youtube player in my smartTV app. I have developed this app using HTML, CSS and jQuery.
But I'm facing TV remote focus issue on youtube player controls.
Can you please provide solutions, how to achieve this.
