Lg smart tv switching off automatically
By Will M
By Lesbo
By Pranay Mokida
By Rex G
By JamesH
Hiren Chotaliya
My lg smart tv 43LH600T is getting switched off automatically while running.
When i switch on again only three times red light is blinking but not getting switch on.
Sometimes internal speaker sound also goes off.
