Tv switching off
By Pranay Mokida
By John Nguyen
By starwoodtech
By cptl
Any thoughts?
By DAJ
I have an LG tv 43UP77006LB.BEKFLJP. Just recently, having owned the tv for a couple of years, the tv has taken to switching itself on during the night, usually at about 2.00 am. The tv is connected to a TalkTalk box for recording purposes but that has never caused an issue before. It appears to coincide with connecting a DVD player using an HDMI cable to the tv, although it was only connected for a short time and is now disconnected, so it may be irrelevant.
It appears to be a common problem.
Thanks.
