Hi guys, is there a way to turn off the pop up recommendations on the latest updates when you hover over apps? My kids use the TV often and sometimes inappropriate thumbnails appear and I would rather have it off.
Thanks.
    • By u84six
    • By Low Grade
      hi,
    • By yippie_kiyay
      My new LG TV (65UM6900PUA) running WebOS 04.71.25 works great with HomeKit, with the exception that it is not reachable while it is turned off. If I try to turn it on in the home app, it says "No Response."  I have changed the 'Turn on via Wi-Fi' setting to on, and it will turn on from the 'LG TV Plus' app, but not from the iOS home app. Is there a specific setting or something I need to change?
    • By Cihanimus
    • By bos2prov
