Can't connect to the Internet
By Mandx
By JamesH
By DavidSr
By Fredrik Andersson
By akhil7j
- 0 replies
- 2,610 views
- 2 answers
- 2,379 views
- 1 answer
- 2,889 views
- 4,247 views
Mak
Hi there. I have this problem. I had the LG 49U67V turned off and the power cable not connected to the electricity socket for 4 days. Since reconnecting everything I can't connect to the Web. Neither by WiFi or by ethernet cable. The TV seems connected in the settings. But the the speed is practically zero. This is the case with WiFi and with ethernet.
No it not the case we're the WiFi disconnects itself and which is solved by disabling the Quick start functionin the settings.
What happened?
