Which single button push to activate Sky Q menu
I got an LG OLED today, I only have a Sky Q as input (no other devices). I want to stop using the Sky Q remote, which button on the LG magic remote acts like the "Home" or "Sky" buttons on the Sky Q Remote?
The magic remote can pause/play and power off the sky q box as well as navigate the menu (after I call it up) all with single button pushes. But to get the sky menu - I cannot find a way to get a single button push on the LG to bring the sky q menu up. I found a couple of ways
1) press the STP power button twice (off / on = brings menu up on power up)
2) press the ... (three dots) button then scroll down to menu from the pop up menu.
I want a single button to bring up the Sky menu ... any ideas? Maybe it's possible to configure the 4 coloured buttons or the GUIDE button on the LG remote to map to the Sky Home/Menu feature
Thanks in advance
Dave
    • By David Daul
    • By Dennis Radliff
    • By JonoW
    • By Marko00
      only with cancel button.
      How to fix it?
    • By Damian1
      After searching high & low, & also on the difficult to navigate LG website, I can't find which magic remote is compatible for my TV.
      The model.of my LG TV is - 32LQ630B6LA
      Can anybody assist, please?
      Many thanks.
