    • By informatiko
    • By Kane Murphy
    • By Flavio_S
    • By valoufifa
      I’m French sorry for my poor english
      I was wondering if it’s possible to disable simplink (or only auto sync on) only on 1 HDMI device.
      I have an LG C1, multiple HDMI devices which work perfectly with simplink, except an LG Blu-ray 4K player (UP970).
      When I turn on a device, it turns on the TV, great! But if the Blu-ray
      player was the last device I used, and I turn everything off, and then
      I turn on a device, the TV then turns on and shows first the HDMI
      Blu-ray player input (with no signal), then it shows the HDMI input of
      the device I turned on, and finally the Blu-ray player turns on and
      the TV switches back to the HDMI Blu-ray player input...
      Any ideas on how to fix this?
      Thank you!
    • By Jei
      I have LG 65C1,  Denon x4300h(arc monitor 1 was broken, but monitor 2 is working ),
      and what I would like to know is,
      can LG TV's autopower sync works?
      I mean I want to turn on TV using  the LG remote control,
      then my Denon x4300h could turn on automatically,
      when I turn off TV, then Denon turn off automatically.
      I tried many ways to test it, I open all the functions about hdmi control, hdmi cec, simplink, autopower sync...
      but it still doesn't work,
      how could I solve it?
      Or LG TV  just can't do it?
      Thanks a lot!
