Wifi Connection - password not retained
Posted (edited)
I am in the process of moving my WiFi to a 4G carrier. I was testing the 4G modem and needed to move back to the Broadband modem for a day - I found that the BB password was not kept on the LGWEBOS TV.  Similarly when I moved back to the $G modem I had to re-enter that. This TV is the only device that I have which does not remember passwords
Is there a way of placing a support ticket for a change to the OS
Edited by Allan B
spelling correction
Hi @Allan B
You would have to go to the LG Customer Support on the website relevant to the country you are in to raise a ticket, this is purely a User-to-User forum.
    • By akhil7j
    • By Tunari
    • By Ramesh Chand Vishwakarma
      Regards,
      MD/CEO
      Noida, UP
      +91 9910246766
    • Guest
      By Guest
      Things that I've tried:
    • By Trung Hiếu Trần
      Specs: LG OLED 55C3
      Router speed: 250mbps
      System: webOS 2.3
      Any ideas on how to fix it?
