NTFS Symbolic Links via USB external HDD
By mycop
Greetings.
By bos2prov
By Velvet_Noir
Hi, I have the option to right click and pick the subtitles on my Mac when watching movies in the VLC Player, but I can’t do this on the LG OLED, though. I already renamed the subtitle file to be the exact same as the video file and I did have the SRT file in the same folder where the movie is. However, when I connect the hard drive to the TV, the subtitle still doesn't appear. The format of my hardrive is NTFS. Can anyone please offer some advice?
By Scotty
Hello, LGLovers
I'm looking for pure clairty here, so I have a 43lm6300pla and it's my wish to plug in an external hard drive to record freeview. Now I was under the impression you could get a 2tb hard drive, plug in and go but it seems a lot more difficult than that and I don't want to spend a fair amount of money for it to be useless.
The information on the TV regarding the criteria is a bit contradicting. Basically yes use a external hard drive but don't use an external hard drive. Use a drive that's powered by a cable.
The Seagate expansion plus 2tb sounds utter perfect but I'm too apprehensive to purchase it.
If some one can shed some light on this I'd be almighty grateful
S
By AndreasGr
Can someone offer a solution on this problem that I'm having with my newly purchased Qned lg TV? I have multiple video files most are mkv files 1080p stored on an external hard drive where when I connect via usb it will play them but with no sound. Some videos will play but majority won't. Any info is appreciated
Codeq
has someone used Symbolic Links with an external USB GPUID NTFS formatted disc? They write, they support NTFS on external drives, but with the tested hdd's it doesn't work. accessing normal files works finde, but using symbolic links doesnst show any file.
I tryied on OLED65C9 with WD Elements 4TB GPT NTFS and WD Black_P10 5TB GPT NTFS.
Thank you and best regards
