Hi guys,
my LG lb652V has serveral buggs and i want to get back to factory settings. Everytime i go to the menu and choose the factory settings, the TV do a reboot change my TV list to Cable and thats it. No apps deleted, no first install assistant, no settings are reseted. Then i used anymote, to do an INSTOP reset, i checked the service menu, and so on. I cant reset my TV, what should i do anymore? The TV has the newest firmware 05.05.70 so i can´t downgrade anymore, i tried it several times. I dont know what to do now, has anyone an idea?
Sorry for my bad english, im german.
The reset will only reset using the current firmware, not the original or earlier.
Try unplugging the power cable from the wall for at least 5 minutes and then check the TV
    • By David Daul
