bluetooth keyboard
By JamesH
By Fredrik Andersson
By ato53
I have a new C4 TV.
Thanks for the follow-up
By Kane Murphy
By janisad
I have an LG 32LJ610V TV.
ruitertjelg
is there a way to make the tv accept a logitec k380 bluetooth keyboard?
regards,
Jan
