Google assistant missing
By Cody LUEN
Hi!
Version: 23.20.36
By Lleuadwen
Hi, I hope someone can help. I recently bought this TV but can’t find the Art Gallery app that is supposed to be part of the Home Screen. I have searched in apps but only third party art gallery style apps show. What am I missing here?
By Flavio_S
By techguy noob
My LG TV model number 32LM560BPTC is having an issue where the Sun NXT app is no longer available on the LG Content Store. I was able to watch it before, but starting yesterday, the app disappeared. However, on my other OLED LG TV, the Sun NXT app is still available in the LG Content Store. Is this issue specific to the 32LM560BPTC model TVs?
Sarath
By toopie28
Hi can someone help please.
Not sure what else to try.
Thanks!
- 1,577 views
- 1 reply
- 4,868 views
- 1 reply
- 3,739 views
Using the magic remote with Google assistant to operate wi-fi socket outlet
By fade2gray,
- magic remote
- google home
- (and 1 more)
- 1,997 views
Husny Nazoordeen
hi, i have a uk6300 webos tv. i baught it becase it said google assistant is available.but what i tried to add voice commands i found that aoogle assistnt, alexa and home dashboard is mising and cant find in the LG store..and it has limited amount of service countries to select. i am in sri lanka and google assistant works in my phone.plas help me to install google assistant and home dashboard on my TV.
