replacement remote for lg webos tv
By Roy Brown
By Khelben Arunsun
By magicschooldropout9
By RJ Fischer
soopergoob
my original magic remote is on its very last half-a-leg. i ordered what was supposed to be a suitable replacement as i was informed that my particular model remote had been discontinued. the new remote is an LG AN-MR700 and it will not register to my LG webOS tv. i can control power and volume only. pressing the ok wheel attempts to register but comes back as fail after about 30 seconds.
