  • 2 weeks later...
    • By pivotCE
      3. Soldering iron and solder
      2. Items 2-4 above
      1.
      2.
      Prepare the Wires
      Final Thoughts
      #webos4ever
    • By pivotCE
      Tools for the Job
      – Needle nose pliers/tweezers
      – Flush cuts
      – Painter’s and kapton tape
      Trim the USB C Board
      Tape the USB C Board
      Where To Get Power and Data
      Put the Pieces Together
      Congrats, You Now Have USB C
      #webOS4ever
    • By Jackie1701
      Is it possible to link an iPad to  an LG OLED55E9PLA? I want to watch streamed operas from the Met Opera app it doesn’t appear to be available on the TV which is probably as the US isn’t an available country so far as I can see.
    • By ajmboy
    • By Alex
