Latest update gone haywire
After update, sound and picture is gittering.. picture jumps and sound goes quite then very loud every second. Can I reverse the update
this occurs on TV, Netflix, and Prime,  so it is not an app issue..
how can I fix this.  Turning tv on and off does nothing
    • By mean2
    • By OliverRC
    • By Ajothen
    • By Batman
