Connectivity problems on lg 43UK6300PLB
Hey guys i live in spain and i have the  lg 43UK6300PLB smart tv.... the problem is my connectivity speed i have 600mbps download and upload at home but the problem is wheni go to smart tv web and go to fast.com or go to speed .net i only get 90mbps max i tried wired and i tried wifi ... and the ping on the tv gets up to 140 to 200 i mean why i checked everything reset everything and i still get that amount as max and when i do the test run on my laptop i get the full 600mbps!!! i am just mad as i couldnt figure it out... i tried all online solutions but nothin!! please help
The network card in LG TVs are 100mbps, as is the case with the vast majority of other Smart TVs.
@George Hofmeister I am sure you are correct about the LAN side (100mbps, no 1Gbps LAN yet) but most newer LG sets have WiFi 802.11ac support, so that should be much higher than that, especially on the 5GHz band).
@Amir Abulajras  have a look at my post about a snippet I found on another forum (if you are using the 5GHz band, ensure you are using a channel below 100, I find 36 works well - I assume you are able to log into your router OK, for you to do that change of channel under the WiFi advanced settings or setup) :
"Network/Ethernet/Wi-Fi
Problem: C9 [or other models] will lose the wireless connection and you have to reconnect daily (but wired is stable);
Conditions: TV is connected to a 5GHz router;
Cause:           (1) the router may be unstable on the 5GHz band [possibly too far from router]; (2) the router has the 5GHz band set on a higher channel - over 100;
Resolution: (1) change the TV to the 2.4GHz band OR
                          (2) set the channel [in the ROUTER advanced WiFi settings]!! for the 5GHz band below 100 (ex. 40-50) - [channel 36 is often OK]."
    • By John Nguyen
    • By Nick Payne
    • By LG tv fan
      Recently live channels stopped working with an error every 2-3 seconds.
      Older media is still playing.
      Now I noticed that new media like today's news aren't playing either. Same error.
      News from Friday 3rd may still work.
      Have tried on 2 LG tvs.. Oled from 2018 and LCD from 2020
    • By Puja aingh
      Respected Sir 🙏
            LG WEBOS LED TV MODEL NO 32LK628BPTF AUTOMATIC WIFI CONNECT IS DISCONNECTED
      PLEASE SOLVE THIS ISSUES
      Delivering the First Commercial Implementation of HCA Specification 1.0,
      Company Expands Smart Home Ecosystem Through Partnerships With Other Brands
      SEOUL, Aug. 29, 2023 — LG Electronics (LG) is set to present the first commercial implementation of the Home Connectivity Alliance’s HCA Specification 1.0, enabling cross-brand appliance connectivity through the LG ThinQ smart home platform. By the end of this year, consumers will be able to control appliances from diverse brands, such as Samsung and Vestel, with the intuitive-to-use ThinQ app, providing seamless interconnectivity and a smarter, more convenient home.
      With a firm commitment to customer experience innovation, LG has joined with other brands to bring the elegant simplicity of cross-brand compatibility to major markets worldwide, including South Korea, the United States and Europe. The partnership will initially cover major appliance product categories, such as washing machines, dryers and dishwashers, and will gradually be expanded to other types of appliances in the future.
      The widespread adoption of HCA Specification 1.0 to development makes it possible to monitor and control various brands’ home appliances and air solutions using a single application. With the ThinQ app, users just have to register their compatible products, and then they’re ready to enjoy the ease and time-saving freedom of one-stop device management. Those with an LG washing machine and a Samsung dishwasher in the home, for example, will no longer have to switch between each manufacturer’s app to set their preferred wash cycle and cleaning settings.
      The arrival of true cross-brand interconnectivity is the realization of the HCA’s vision for a seamlessly unified smart home experience. Founded in January 2022 and comprising a number of smart home solutions manufacturers, the HCA aims to provide cloud-based interoperability between the smart home platforms of its member companies. As a board member of the alliance, LG has been working closely with other appliance makers, including Samsung and Vestel, to drive the adoption of HCA Specification 1.0, with the ultimate goal of enhancing user convenience.
      Committed to expanding the smart home ecosystem, LG has also actively supported the work of the Connectivity Standards Alliance (CSA), a global organization dedicated to developing open communication protocols for smart home devices. LG contributed to the development and standardization of the Matter protocol, an Internet Protocol-based home IoT communications standard led by the CSA.
      “LG ThinQ enables a seamlessly interconnected home appliance ecosystem that will provide new smart home experiences to customers around the globe,” said Jung Ki-hyun, executive vice president and head of platform business center. “LG will continue to expand compatibility between ThinQ and other HCA members’ smart home platforms.”
